Davinder
158
31
28
Wymington
Just need to pick your brains for a moment guys/girls.
Now this flue (For an Ideal Iasr 24 HE) Terminates into an internal space (some sort of out-building/Lean-to), So we've ID the boiler.
Now we're a bit stumped about how to re-run the flue so that it terminates safely.
Here’s a Picture of what I’m talking about:
It's been suggested to us that we could just put a plume kit on it, but I thought that you can't use one of those as a solution to a terminal position problem, (there just to 'manage the plume' so that it doesn’t cause a nuisance to, - say your neighbour). Correct me if I’m wrong.
Also in different properties I’ve seen (where they've had a similar problem) they use a normal horizontal flue kit, but put an elbow on the end and continue the flue run vertically, till they get to the end and put another elbow on with the terminal off-cut from the horizontal flue kit.
What would you suggest, because I’m not sure what the best thing would be to do here?
Plus (this may or may not make a difference), it's 650mm away from a internal corner.
can the boilers location not be moved?? the flue itself doesnt look in great condition.
Can hardly see the picture to be honest , but as alreday posted . Try move the boiler if possible.
I've already suggested to the custard to move the boiler, but he wants it to stay here it is.
Try this:
(If you hover the mouse icon over the pic, it should en-large)
stick an albow or extension on top of the boiler and try and exit it somewhere else ?
Thats what i'm thinking, but to the left of the current flue terminal is the internal corner and i cant go right because the MI's state that i can only use 6 extension bits and so the flue run would be to long.
so i guess the only way is up?
elbow it up through that plastic roof
Ok. elbow it up, but then what? Put a vertical terminal on maybe, but they a different size?
Or could i get an extention bit and again just elbow it up and have an elbow on the top of that with a horizontal flue terminal on the end?
Or could i get an extention bit and again just elbow it up and have an elbow on the top of that with a horizontal flue on the end?
just an extension kit and appropiate terminal
i'd elbow it up through the plastic roof, but ask the owner if its ok to cut a section of wood and plastic out, then another elbow above the roof to point the original flue terminal out and obviously clip it all up and seal around that diy roof
Thanks for all the replies guys i think i'll go along with what mickie said and hope for the best.
