C
Hmm my view...
without the databadges + heat input.
how can you 100% say the meter is big enough!
Ive allways avoided fires when I can but for a CP12 you are required to do exactly the same checks and tests as when installing. For example you may perform a spillage test which passes fine but without removing the fire how can you tell the flue is clear? If there is no liner how can you tell that no mortar is missing from the brickwork? or that any gas pipe inside the builders entrance is taped up?
In reality as soon as you do any work on a gas appliance you are then from that point responsible for it, so a lack of identification should mean you disconnect it and make it safe until it can be identified and tests performed on it to the MI.
I went onto a job where i knew lads doing 12 plus a day with maxol 5 units with fires, 1 to 2 other fires and convector heaters in each property. Most of the time id check the name of the last engineer and know if i was in for bad one. you would get the usuall "why are you removing the fire? the last few guys never did that". I found some really bad things, even catchments filled above the appliance spigs.
now i see alot of service engineers just enter a property with there FGA and a few screwdrivers, even tho the MI requires you to strip, inspect and clean when needed. The problem is they are coverd by the contract, if they screw up its a work mate who gets them out of the dodo.
When you say strip and clean where needed, do you mean if combustion proves to be wrong, or do some boilers require it regardless?I went onto a job where i knew lads doing 12 plus a day with maxol 5 units with fires, 1 to 2 other fires and convector heaters in each property. Most of the time id check the name of the last engineer and know if i was in for bad one. you would get the usuall "why are you removing the fire? the last few guys never did that". I found some really bad things, even catchments filled above the appliance spigs.
