No words required .
That's supposed to be a 75mm gravlon screed?
I thought it was a making good effort after being sliced due to external 5m of flat 21.5 on its arse!
Spending a penny
Found this under the floor of a house we were 1st fixing, this was a live, in-use gas pipe
This isn't a wind up, its genuine
It must have took longer to solder in position than it would have to go to the merchants (1/2 mile away) and get the right fittings
Just in case anyones short sighted, yes it is a one pence piece
Reactions: 3 people
Sorry. But I can't make head not tail of this photo?
Could you explain please
Open ended gas pipe? :grin: Nah, I'm not sure what the deal is either.
Also, dunno if you can really say this is worthy of the HoS but I haven't come across many bodge's lately:
From top down that's a 6*2 on its side to give sense if scale.
Next is the painted on gyvlon (Lafarge Tarmac screed) always called it gravlon after misquoted a drawing many moons ago. screed, next the clingfilm used instead of a membrane then the insulation then a 28mm gas pipe hacked off to allow shuttering !
So just a tad more than the 75mm depth you were expecting then ? still a good amount of thermal mass now!!
V
UK Plumbers Forums
Deleted member 120897
