Ideal Classic FF230 British Gas Declared boiler "At risk"
View the thread, titled "Ideal Classic FF230 British Gas Declared boiler "At risk"" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi steve ! Are we the only one's to notice that this is-not a steamer ???????????
Steamer lol .... The op probalby doesn't give stuff IMHO .. They're more concerned by sounds of it at the approach the BG engineer took leaving them with out heating and hot water! Good right too IMHO!
arent they suppose to check this sort of stuff before they agree to accept you onto the scheme? i can understand the emissions but obv the flue hasnt moved while the op has been in the service scheme
just looked at ideal classic mi's and theres no mention of a distance from boundary when running paralel to flue axis aftyer getting a high reading then stripping and cleaning if the reading was still high the gas rate and burner preasure should be checked as well as flame picture if all good it can be left on
BS 5400-1:2008 states 300mm from boundary so in that respect it is NCS.
As for the High combustion readings the classic flues are like tracing paper and the inner can rot through within a few years. Giving elevated readings.
Sound like the Engineer was out of his depth and made a sharp exit.
Gas regs on most things are not retrospective which is why they class things as NCS which should really be classed as WGAF. It is a pointless paper exercise brought about by claims are us type stuff. CYA is what it is all about now.
As for the op, the guy on the job only done what was required to keep himself in a job. 99% of people on here would have done the same. It is the way things are these days especially working for the big mobs. Blame it on the claim culture.
wgaf?
Right guys an update, this morning I woke up to no hot water and on further inspection the pump was running but the boiler was not lighting! So after applying the text book fix of turning it off and on again to no avail, I gave the side of the boiler a whack and it sprung into life! Good job the engineer was already booked!
Anyway, it was a different guy this time and he quite quickly found that the gas valve was the wrong one for the boiler, and there was a spiders web partially obstructing the flue!
So he retested it, all levels now correct and boiler firing up, and he removed the "at risk" sign from the boiler.
I was at work and so it was the Mrs who was here again, but she said that the guy wasn't happy about the fact this hadn't been found by the last guy, but none of this was on the report, so I'm guessing he doesn't want to get the other guy in trouble!
How long has the gas valve been in. Before or after BGs last service?
Looks like the original BG bloke got out of his depth.
I'm not aware of it being changed in the time we've lived here (almost 3 years) but I think the guy said that it was the bloke that came out in february!
Surely if it was the wrong valve fitted previously, it would have stopped working sooner, just seems weird it packed up a few days after the last bloke came!
Here's a picture of the Flue and the window, all as was when house was built! The report doesn't actually list what the readings were, just that it failed, but readings were all perfect in February!
That looks alot closer than a meter to me :dizzy2:
More like about 2 foot.
Anyway, with that aside it's not likely to be anything majorly wrong with the boiler and probably just needs adjusting slightly.
Like everybody else has said, if they wont come out to fix it ASAP get somebody who actually know's what there doing in, and then pass the bill to BG
So no proof that it was wrong valve, would have been under orders not to leave any evidence, have you thought about changing insurance cover
BG engineers should not leave any old parts behind. They are supposed to return them to their distribution center to be properly disposed of.
Hi Guys, a further update or should I say correction!
When my wife came home from work I asked her to tell me in more detail what the BG engineer said and did, and basically with the help of an exploded diagram of our boiler from the manual, she identified the part that he replaced which was in fact the air pressure switch and not the gas valve as she previously told me so apologies for that!
The guy looked it up on his computer and found it was the guy in February that had fitted it (I still don't understand why its taken this long to fail!)
He also said (like the rest of us) that he doesn't understand why the guy did what he did on Thursday!
Reply to the thread, titled "Ideal Classic FF230 British Gas Declared boiler "At risk"" which is posted in Boiler Advice Forum on Plumbers Forums.
Carlos_UK,
REDSAW,
