Deleted member 56158
Worcester will recommend fitting a llh, we've done several banked systems, it stops cycling, also Worcester will recommend you alternate the boiler thermostats annually.
Tichelmann
We use it with cascaded boilers and heatpumps and cascaded buffers. (Both on the collector and emitter sides of cascaded heat pumps)
When you one have a single circulation pump as per this installation it ensures flow goes through each of the boilers equally.
Though it may also be used in heating distribution systems for similar reasons. (Makes 'balancing' a whole lot easier 🙂 )
Tichelmann system | Grundfos
