Dec 28, 2012
910
Hi on some new new build houses I plan to first fix the up stairs radiators in 15mm copper coming up though the floor at the pipe centers for the radiator. i,e rad. length add 45mm per side and the correct distance from the finish wall. However I am debating how to feed the downstairs radiators, this pipe work is usual feed behind the dot and dab plaster. What do people find is the best way of doing this. Thanks for any advice.
Yes thanks for the advice. Do the rad valves above work with polyplumb pipe and liners, or do you need a liner specific to the valve?
no if 10mm valve (not the reducer type) they should but never used poly as most of the time im ripping the stuff out but as with any plastic pipe use an insert/liner
