View the thread, titled "Shower pump problem" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
O
ozzy
Hi all,
I fitted a new mixer shower, which I advised the customer would probably require a pump.
After using shower customer asked me to fit a pump.
I supplied and fitted a pump and all was working fine.
I got a call from the customer to say pump not working no water.
Disconnected pump and connected up pipes and still no water. I removed the shower valve and had water out both pipes.
I removed elbows off shower valve and blew into the elbows to ascertain if the check valves were opening correctly Cold was ok hot failed to open. I freed the valve and refitted the valve and checked for flow of water which was ok.
I refitted pump and all was working ok.
Customer called that evening to report shower not working again.
If the check valve on the hot side has stuck again would that prevent the pump kicking in at all?
Is it a faulty pump or shower valve?
I preferred that too. New one is pants.
Tbh I'd be happy if the plus came with the same valves as the logic, or at least 2 blanking caps. I fit external loops anyway.
Reply to the thread, titled "Shower pump problem" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
