stratplus
953
102
43
Hi all,
Need to replace my toilet syphon in an armitage toilet. I measured from the bottom of the internal cistern to the very top of the syphon. This was roughly 275mm which is pretty much 11". Is this the size I need to buy? They come in all different sizes 7,8,9 (litres or inches).
It is a 9 litre cistern (water level is st the 9 litre mark). I don't want to order a 11" syphon to find I can't get the cistern lid back on.
Other options I see are to replace with a fluidmaster or a Dudley turbo 88 which are adjustable To me it depends on the lever action on the handle, surely this dictates the size of syphon.
Thanks for reading🙂
If you had have fitted a lower syphon (sometimes if no overflow fitted) and the wire link was then too short, you just need to replace with a longer link. I keep a few brand new and second hand stainless steel links as spares.
Just be careful if your Armitage toilet is the old type, as it might be double syphonic and have an Airex screwed to bottom of Syphon.
Reactions: 3 people
Good point, the dreaded Syphonic toilet.
I have an Armitage Syphonic toilet in my own house which is over 40 years old. Only thing I ever had to do was replace the small Airex washer a couple years ago.
I like it and prefer the internal bowl part in pan because it is raised.
But very easy for someone unaware of what type of toilet it is, to remove the cistern a little and snap the Airex. Armitage loos must have an Armitage syphon to go with their brand of Airex, because it has a slightly wider diameter. The smaller 8" Armitage syphon will also work fine.
If I was the OP, I would just repair the original syphon. Just usually needs a washer. I rarely have to replace syphons, although the 2 part are handy for the future
The rolls royce of toilets the syphonic. Even better is the fact there are few people who know how to fix them 🙂
Very true. That's what I love to work on, - something most plumbers and diyers don't/won't work on and then I look like I am an expert!
:smug: £££££
It is about time I charged plenty for such jobs.
The turbo 88 only seems to be available in 7.5-9.5". Tha current syphon measures 11" from top to bottom. Is this likely to work.
The 9.5 adjustable goes from 191-241mm. 275mm is 11". That link says the max it adjusts to is 241mm which I think is 9.5" not litres.
where are you measuring from bottom to water finished level?
if you want to wait till tomorrow i can measure one for you but 80% sure it will fit
In my experience of where I had to fit a lower Syphon, I find the normal water level is still achievable about the same. The 11" high syphons were well above the water line.
In fact, the lower syphon will begin to flush quicker and much easier when handle is pushed down because it now only requires a shorter lift of water inside the lower syphon to start the flush
Exactly that.
Doesn't matter how high the old syphon is as long as the water level is below the new syphons water line it'll be fine and different length c-links will make sure the handle can still settle roughly horizontal.
Reactions: 3 people
Snowhead measured a couple for me in a thread last year, here's his findings:
I've just measured a 9" as 10.3/4" maximum height including washer on the bottom to where the screw goes in.
From Dudleys website, bottom of page; Syphon, dual flush syphon, toilet siphon - Dudley Turbo 88.
254mm 10" part no.313879
That'll be 11.3/4" in real terms.
Thank you to all who have contributed. Been a great help and is much appreciated!! 🙂)
Ooops.
Just changed one of these today and fitted a Fluidmaster cistern kit to the cistern with flush lever.
The old one was knackered as the customer had adjusted and fettled with it over the years and finally managed to shear the part of the syphon that the linkage goes onto.
Fluidmaster dual flush kit with the cistern handle flush lever fitted no probs and all operates correctly and the flushes are more efficient than the previous setup.
Cheers,
Andy
