Yes, long time ago. There is no big difference surprisingly, less than 0.5 CHave you calibrated and offset the Tado TRV temps?
Might not make much difference but they are obviously reacting to the nearby radiator air temperature and not necessarily the actual room temp.
The temperatures should drop rapidly if both pumps are still running which they should be, we don't know what the primary pump is circulating but would think its quite high.Right now, for example, I see the picture of boiler that turned off burner and for whatever reason temperature doesn’t drop fast, so this time it managed to heat something. But, difference between flow and return on LLH is 2 C. While there are still 5 radiators open, not including UHF and other stuff.
Or pumping from the top (left) secondary pipe since the boiler pump will more than likely be pumping through its own heat exchanger.Is the secondary pump installed correctly, the boiler circ pump is pumping into the top right primary pipe and returning through the bottom right primary pipe via the secondary pump, thought the secondary might be pumping into the bottom left secondary but maybe not?.
External heating circuit pump is always set to 40 W power, never seen it to change. Boiler can and does turn it off when there is a need for DHW, but in any other time it is turned on.You can derive what the secondary Wilo pump is pumping from the following info.
The Wilo pump on this picture is not a heating circuit pump as far as I get it. If i remember correctly, this pump helps the return flow back into the boiler. The main heating pump can be seen on the last picture. I would guess that all pumps do work as intended, because sometimes boiler works and heats the house correctly?Is the secondary pump installed correctly
I think there is this pump + own boiler's internal pump?Does this mean that all the flow of water through the boiler is via this pump, it showed 15W in one picture, if so then we can derive the boiler flow if you provide the info, above.
Attached.Should be a sticker on the top at the back left can you take a pic of that plz as I’m sure there isn’t a pump inside the boiler just a heat only
Attaching photo. This pump is set on c2, 15 W.Have a look at the attachment to see if pipe and the other Wilo is teed into the boiler return.
I am guessing that my boiler has internal pump based on the information shown in ViCare app. I could be wrong.Is that with an external pump set as I don’t know if one (42kw) with an internal set ?
Thanks,Attached.
I appreciate Your help, guys. Thank you.
You mean a pump that is in lower left corner of the picture? This is a DHW pump. It turns on when there is a need to fill and heat hot water cylinder.Thanks,
The other Wilo is feeding into the boiler return as well so looks like the main (a external) pump.
Can you post a photo of this one as well please with the same info re type, head etc and its setting and power.
