G
Guest123
.....is 120 ok for cleaning copper pipe? I'd like to try it instead of steel wool and any recomendations would be helpful.
As an apprentice I was told not to use emery paper on copper, can't remember why though.
I would use the cleaning strips designed for the job
I read in an ancient plumbing book that emery shouldn't be used if you are going to solder as whatever is in it will react with solder. I think using emery & then steel wool is fine. I will have to get in the habit of using abrasive strips. I use emery cloth (not sure grade) on old tarnished pipe or solder fittings & steel wool last. I steel wool new pipe, but only use the milder grease based flux.
Jeez I didn't tink I was that old 😉
been buying from said station for a while, never noticed these rolls. will get a roll next time, thanks for the suggestion.if you like to use the cleaning strips then you can buy a 5mx100mm roll of the same stuff from a station that sells tools.
how do you go about getting an account with them????????AW, can u post a link or pm me with it? Cheers for the advice, I've got a account with them.
