king of pipes
Subscribed
Dec 20, 2016
6,156
4,335
113
63
Norfolk
Heating Engineer (Has GSR)
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Reactions: Admin
baxi solo think it’s graveyard time suggest as a last option they phone baxi up maybe for a fixed price repair
Home straight now on this one
Reactions: SimonG and Scott_D
You get all the good jobs. You do, don’t you?
yep this one was 11 years old and some dopey person replace the burner gasket 3 years ago without pulling and cleaning the baffles they prob would if come out then
went to another one this afternoon and the last engy said he couldn’t adjust the gas rate past 15kw on a 30kw boiler as it was breaking the law 😀
guess the ppm went high once he’s passed 15kw so just made it up to get out fml
I really try to not criticise other engineers as it is a pet hate of mine, but people do make it difficult sometimes. 🤣
I slated him doesn’t help I wasn’t in the best of moods who installs a heating system on drops with no drain offs had to drain with little tubs 😀 took me 2 hours to swap a rad valve because it was leaking
Done and dusted on this one has took a while but custard is happy. Kop
  • Winner
I did this bathroom back in 2014 the elderly lady can now no longer manage getting in and out of the bath so to keep her independent I am fitting one of these 😉👍 kop
18 year old through the wall mounted oil worcester. Customer had loads of issues with original installer. Looked after it for about 6 years, sorted all the issues re not holding pressure, wired wrong etc etc etc.
Went to service it today.
Pricing for a new internal floor standing hounsfield.
Got the easy access bath fitted few bits of trim to fit and tap end panel to fab up but its now usable for the elderly lady, have a nice weekend chaps . Kop
Reactions: Jim Goodenough
Finally got this one done. Lot of unseen work on this one.
Nice job Simon how many days did that take bud ?? Cheers kop
Cheers. 5 weeks. Everything moved, single storey extension on back making it nigh on impossible to get at what used to be the external pipes and things arriving not as what the customer told me originally.
Start a nice 4 day bathroom tomorrow. Bath out, free standing one in and replace the pine cladding behind it. New toilet, new basin and a little 760 square shower cubby hole that's getting wet walled.
I am finding jobs are taking longer than expected mate the finishing touches seem to take forever 😅 people really don't appreciate how much work goes onto these, i used to be able to do one in 2-3 weeks 5-6 k parts and labour now creeping like you 4-5 weeks but the extra time is not relative to the labour cost i find it hard to charge more than 3.5 k for labour in my area break it down into day rate then it not great how do you work out the labour cost ?? Regards Wayne ( kop)
Labour is normally 2 to 3 weeks. Customer knows this one is going way over. Will sit down tonight and do the invoice for them.
Reactions: king of pipes
I’m sure I can count the number of bathrooms that I have run to schedule on one hand.
This next ones not looking good. It's less than 2 miles away. Shredded a tyre on the van going over this morning. Put the spare on and shredded that coming home tonight.
On the plus side, when I've pulled out the old bath the pine cladding and skirting board I thought I would have to patch up is all intact. Bonus.
What are those wall mounted taps bath taps Simon?
Any good, how is flow rate?
They got them from something similar to bath store. They came as three separate bits. Needed male iron connectors and fittings to connect them up. Flows decent, but they're running off a combi. Quarter turn operation.
Reactions: Aquarius
Was it under warranty?
How are they replaced?
These were wired to a plug so can’t just swap with a standard 2 port
Yes Scott was replaced under warranty complete with wiring and plug personally i wouldn't use one again i would make my own one up, looks like they have changed the valves now bud 😉. Kop
Thanks for the heads up.
I was quite impressed with the setup, comes with honeywell valves and the wiring centre made it easy to connect, I didnt need to involve an electrician. Could have done with lockshield/gate valve on the hot water return to throttle it down a bit but no space to cut one in.
Cost less to buy the pre plumbed than a standard cylinder and all the bits.
Yes mate good value for what you get but caused me alot of grief the job was 2 hours from home and 3 visits to get it sorted pi--ed right off 😜
I hate those ESI valves. I have fitted a couple of those cylinders which come with them and both have had a valve which has leaked from the spindle in about 2 years. Not impressed.
Ensuite shower room upgrade bit of a mission removing the multi panel and it's hiding up a multitude of sins . Kop
  • Love
Reactions: Aquarius
Putting it all back together strengthening the metal stud wall plenty of timber for fixings for later, damaged dot and dab removed and replaced, toilet frame fitted drainage altered to suit stud work done ready for ply.
Me knees 😀 not bad for a day and a half still hate plastic
Finished a little oil boiler install.
I haven’t fitted any of them but would like to try one.
Do you find them a pig to pipe up as it all looks very close around the valves and PRV?
with these you have to do the prv first but other than that there not too bad
I normally work right to left eg return mains gas etc
