king of pipes
Subscribed
Dec 20, 2016
6,156
4,335
113
63
Norfolk
Heating Engineer (Has GSR)
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Reactions: Admin
Ok, so basically, the installer assumed blue wire was neutral, L - N was approx 10Vac, N - E was approx 248VAc, L - E was approx 248Vac, so originally I assumed reversed polarity.
What was actually happening was blue wire in spur was switched Live, so boiler would only work with the old room stat that was left connected.
The stat was obviously left in a position where the boiler would operate, and was either turned by customer (said it hasn’t been touched), or it wouldn’t work, as temperature was high today.
Proud of my findings today though.
Nice one mate that's more like it .
Week before last and this week (I was off for a week in between) I’ve been installing “smart” products. Some thermostats that can give feedback for humidity levels etc, and some boiler monitoring devices. Also done a big fookup moment too (I will post on another thread).
Reactions: king of pipes
Is that a transportable caravan?
ie: One you tow behind a vehicle for holidays and adventures?
Reason I'm asking is because we have bans on using press fit fittings in caravans.
We can't use them at all in Caravans.
Something to do with constant vibration when traveling, press fit fittings can become loose and leak.
It’s a static caravan / residential park home. It’s unlikely to ever move.
Not much to post on the work front , I've been on a trip to Porto in Portugal for my 60th birthday my wife surprised me on Thursday last week and we flew out Saturday for 4 days, had a great time and was throughly spoilt , we got alot done and saw alot the Douro valley was breathtaking and well worth the effort how they sculpted the valley to produce the vines was amazing the architecture in the city was breathtaking had some really good food and wine and family time .
Only damper was I had a positive COVID test when I got home not felt 100% during the trip but been so busy didn't worry about as was out in the fresh air each day , now resting up I did a bit of work Friday in a empty house but nothing over the weekend. Regards kop
Looks like a cracking trip.
Take it easy.
Just swapped out a classic for baxi 616 with rear flue. Told the customer I'd replace toilet internals if boiler went well and I ran out of things to pretend to struggle with.
Regretted it on my way to van for the angle grinder!
That's a coincidence I've got this one to do condemned it yesterday hardest part is finding a Baxi boiler 😂 any pictures of yours bricking the flue up can take a good few hours
Busy bee. Last three jobs done. Just finishing up the outside work for the first photos.
Found the cause of the overheating of the old girl I couldn't source a Baxi so a Glowworm Easyheat will be installed tomorrow it's £300 Cheaper and still has 5 years warranty so will do the job this will be housed in a kitchen wall unit in the utility room . Kop
Got a bit more done on this one chaps empty house that's being renovated so not under any pressure. Kop
Final push on this bathroom just can't seem to get the damned thing finished this heat is really getting to me , work life balance is the worst it's been 3 decent size jobs on the go which I hate, I've got to start turning work away as I'm booked up till end of October . Regards kop
Need to look after yourself.
  • Friendly
Got the boiler finished off today a little annoying I had to run a cable from the pump direct to the boiler for overun have a relaxing weekend chaps
Just finished this off on Friday.
Labour and supplying stuff and materials (Excluding Tiles, customer supplied) £9k inc VAT. Although really should have been a bit more, was quoted at our old labour prices.
Although there was very little electrical works on this one, plus everything basically stopped in the same place.
Floor was a mess underneath so was another £250 on top of above for redoing floor too.
Looks good mate. 7 year warranty? Did you mould the probe yourself or buy it that shape😂
Yes and out of necessity (bloody kitchen fitters was before the flexi probe came out) they keep getting flagged by Kane but keep passing 😀
Viessman 222- f - 1 year down the line time to service this ready for winter hasn't been any trouble but not the most enjoyable task everything is so awkward maybe it will be easier next time . Kop
After a run of bathrooms been having a run of Combi conversions getting fewer conversions these days now though.
Looks an awkward one, I'll not be fitting any of those 🤣
Wasn't a easy install and definitely a pita to service but their bills are lower and weather compensation has worked well the customer is tec savy so no worries with the app . Kop
Can’t decide which boiler you like??? 😅
Use Main as our budget boiler - cracking for money.
Vaillant is our go to ‘Premium’ brand. The Worcester one I’d offered them two options Worcester and Vaillant. Worked in my favour for as could run pipes down back.
The Pro is a solid boiler though. Be sad to see it go when it does. Vaillant are just a bit behind with their modulation etc. as new model has been delayed.
Even though I don’t know what I’m doing from one week to the next, it‘s still all similar and mundane. Gas safety checks, occasional boiler fault, and installing some thermostats. Friday was most exciting day when I got to change some wiring going into a programmer, that I think was just being used as a junction box.
What do you do about backflow prevention on the shower hose? Only way I was able to do it on level access showers was a chrome school board clip, or in some instances a shorter hose.
Adjust and fix the soap dish so the head doesn’t go below spill over
Working on 2 ensuite bathrooms on this period cottage drainage is proving a challenge alot of alterations to do and new pipe runs to install alot through triple joists ☹️. Kop
Just had three days converting gravity hot to unvented in a bungalow, plus re routing all pipes in roof space ready for a loft conversion next year.
Had to move feed and expansion for heating and get it all up and running today. Left at 8.00 tonight.
50 minutes later, text message, water bubbling up through kitchen floor.
The only section of hot pipe in the concrete floor runs from under the bath and across kitchen floor to sink, and it's gone pop.
Only thing I could do tonight was turn off hot water.
But now have to fit in pulling up a real wooden floor and digging out concrete to fix the leak.
Not like I'm busy or anything. Ffs.
Its always a risk converting to pressurised Simon I hope you covered yourself before hand mate ? Can you reroute rather than dig up and look for leaks ?? Chances are it may find the next weakness point and leak there ?? Feel for you mate. Regards kop
Reactions: SimonG
All explained to customer beforehand, plus covered in estimate.
No chance to reroute, unfortunately, but had the plinth off under sink unit and it looks like a previous repair was done and I reckon it's the repair that's failed 🤞🤞
  • Winner
Converting a bathroom to have a walk in shower stripped out and starting the rebuild, got the Flova smartbox fitted and piped a bit tricky in a metal stud wall pipes passing through the metal uprights but have sleeved them all . Kop
You are brave taking them pipes across like that. One day someone will go straight through them putting a grab rail up or something and wished they'd never started 😂 Know it can't be helped sometimes.
That gonna be a wallboard job kop? Then at least you don’t have to try and make good that awful metal stud wall - just go over the gaps 🙂.
Have you used flova before, any good?
Not on this one mate going to be tiled all quality stuff on this Flova shower and fixtures and fitting in bronze, 1700 x 800 slab tray that's gonna hurt 😂 10 mm frosted glass panel should look good . 👍
Got floors up trying to find a gas leak as wife said she could smell gas and 0.5 mbar drop on TT 😩 horrible chipboard flooring ended up cicular saw through gas pipe 😩😩😩😩
Got this finished off today the rest of the bathroom will be redone in the new year as I'm stacked out . Kop
Bit more done on this one the shower tray is a beast so getting a hand to lift that in 👍😉.
On with this at the minute, they’ve lived there 55 years and never touched the bathroom. Awkward room for a layout, so done some shifting about.
Tiling started today after a call out to a leak plasterers shouldn't touch plumbing 🤣👍
Cracking on need to get this tiled today clients are home from the USA at the weekend, all going well but lost 2 days last week on another job so I'm playing catch up 😉👍
Reactions: SimonG
Fs run out of tiles and can't get any till Tuesday / wednesday customer supplied everything so it's not my doing 🫣🫣
