K
kirkgas
Hi, thanks for your reply. I am using a 22mm to 3/4 inch flexible tap connector and the olive is therefore imperial size.
i think the label on the flexi is confusing you, 22mmx 3/4" will refer to pipe size as 22mm and female end for the tap as 3/4"
so as you are competant with pipework what you need is to dump the flexi, and buy a 22mm compression straight coupling, a 22mm x 3/4" olive (which goes onto the old pipe instead of the one in the coupling) then get a 3/4" x 22mm tap adaptor and a small cutting of pipe, you could use the flexi but they are mince, haha, the tap adaptor comes with a fibre washer but some are not great and i do tend to use ptfe tape as well, a wee tip to put ptfe on an inside bath tap is to get a pencil and wrap some ptfe tape round it, then you can unwrap the ptfe onto the tap by turning the pencil round and round the tap ( guff description to be honest but try it and you will see what i mean)
