Matt0029
1,245
110
63
37
leeds
Heating Engineer (Has GSR)
When gas rating an oven is there anything one needs to do to stop the phial themostat from modulating down the temperature /flame why I rate it?
If you turn it onto max from firing up it should stay on full for at least a couple of minutes to rate it. I usually do that and then when I come back turn it down to check thermostat and bypass are working. However if already hot I can't see why you couldn't leave the door open while rating.
Reactions: Pssst
