HALL of SHAME PHOTo`s
I think who ever has replaced the boiler on the left thought rather than switch it to a vertical flue kit he has just thought can't be arsed with that and slid it down the same lead slate and turned a vertical flue into a horizontal flue bobs your uncle.... Guys got skills 😀 Long way up as well lol
Ripped this Ariston Combi out today after turning it off yesterday, no flue seal whatsoever between inner and outer flue, made my hand wet with condensation and didn't need to use the flue test point to get a analyser reading haha
Went to install some kitchen taps and found this when looking for the stop tap. It has only been in a week. I left water and power off and told him to get the installer back and check his qualifications! The list of faults is quite high!
Speedfit City!!
Can't see how the expansion vessel will work!
Nice joinery on the stand tho:dead:
I'm correct in saying the EV should be after the PRV aren't I?
(I don't do unvented)
Yea, - after the PRV, between it and the unvented unit it is supposed to be for.
Nothing is to be fitted on that pipe except perhaps a drain off.
Went to classic lxff today and found the case bracket had broken off and been repaired with silicone
Take a look at this soldered joint I melted off. Literally holding by a solder thread and all joints seem same. Some of the pipes are also cut at a bad angle, obviously with a hacksaw. Pipes half in, barely soldered. This is original work (30 years old) on a system now converted to combi high pressure in a flat.
Really shocking "plumbers" could do such consistently useless soldering.
Take a look at this soldered joint I melted off. Literally holding by a solder thread and all joints seem same. Some of the pipes are also cut at a bad angle, obviously with a hacksaw, (this one in photo is done badly with a pipe cutter) Pipes half in, barely soldered. This is original work (30 years old) on a system now converted to combi high pressure in a flat.
Note the fitting shows bare copper never soldered also. I am removing every fitting above the floor, but it is a worrying thought that the pipes are buried in screed floors. Not a good idea to even move the pipes
Come across that a lot on stuff fitted in the 70's and 80's. Some that are fully soldered you can snap off easily. Might be a combination of bad cleaning and the flux but it only seems to be on stuff from about a 10 year span. Saying that it is unusual to find soldered copper stuff from the 60's or earlier. It was all compression or paraffin blow lamps for lead then.
after 30 years warrentys probably void
not clean enough before soldered
Maybe, but it also can happen with lack of flux and/or blasting too much heat at the fitting.
It is a very common fault I believe in the methods plumber use to solder. I have the habit of melting off soldered joints to replace the joint and I find this with many fittings.
after 30 years its done its job,may be ****e but its held up,move on folks,nothing to see here
True :smile: it has somehow by luck held until now, but my point is the joints have been very weak from first day and obviously that plumber would have one or two leaking joints frequently.
Also joints like this will crack easily if we touch a pipe to connect onto and really got to be gentle with any pipes not being replaced. You never know what way a joint is done
"Nice and neat inside your cupboard! No DIY kit fitted here, Outside tap done properly"
Barry98,
Harvest Fields,
