View the thread, titled "Flue dripping from exhaust and from air intake." which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Y
Yashimaki
My neighbours flue is installed on my property & is dripping condensate from both the exhaust and air intake whenever boiler operating. The exhaust has kit fitted and is one metre above air intake so the drips are from different locations but both check out as acidic (i.e. products of combustion). It seems to be a loss of integrity of a seal between air intake and exhaust. Can anyone tell me is this an ID or AR fault and can a registered engineer put an unsafe notice on it.
I feel sorry for the GSR person you get in, walking into a can of worms.
You also state in post 67 that they could give you advise to get your flue to work correctly, which you have already been told is correct!!!
A vertical flue would have to be in the neighbours roof so why would that be considered lucky for me they didn't do that? I'd love for them to do that.
My landlord has no authority to do anything in my garden it would be a breach of contract. Just the same as allowing a flue to be in it. So funny enough a vertical flue would have kept them out the trouble they are in.
Because the plume would be worse for you
0304 Driver. I don't get it. Sympathy for GSR person and walking into a can of worms sounds a bit emotive. Surely the GSR inspector will be a expert who examines the situation and makes a professional report based on his skill and knowledge. I certainly hope so or they will get a can worms freshly dug from my garden (that's meant as a joke by the way)
I think all they are trying to get out mate is that you won't be convinced you've had at least 10 of us on here telling you certain things which are just questioned constantly. If your boiler is installed to manufacturers instructions it will work and fumes will disperse safely. Really you just have to trust the manufacturers on their design as manufacturers instructions are gospel
All I am trying to get out is the flue doesn't disperse whatever may be printed on paper and I have accepted I can't change it so I live with it. I know it sounds extraordinary someone would accept never switching their central heating on and my integrity is being questioned on here so that's why I uploaded proof. I just don't use my gas boiler any more. I've dealt with it. Maybe there's a solution which someone on here could provide or a GS engineer can provide e.g. a diversion kit or a refence to a breach of regs and then I can switch it on again which would be great. As it stands it's not in use. That's my choice albeit reluctant. As I've said an an engineer is being organised so we'll see how that pans out.
Cheers Riley
I'm sorry mate I find it staggering what you are "putting up with" and continuing to pay a full rent to your landlord. I understand your reasoning for staying However I do question what your landlord would do if anything serious ever happened. I'm sorry I just don't buy the boiler bit, If your boiler is installed correctly it will work, end of, unless there is actually a fault with the boiler itself. Good luck with the gas engineer I think we will all be interested to know his findings
Not true. I didn't give permission and there certainly are gas safe issues, e.g. leaks, position, Reg 28 etc.
Its not your house to decide - it seems your a council tennant.
You want to make decisions about a property - buy one
You are a tenant so it's basically nothing to do with you. If your neighbour wanted access they would approach your landlord or worst case go to court to gain access. Bottom line is you are not in a position to stop them.
Go buy yourself a flue gas analyser and take readings at your window.
However I would recommend directing your frustrations at something you are able to influence. Lifes too short.
I get the point Riley. The boiler meets specs. The facts on the ground are the plumes does not disperse as it used to. I will defo let you know the outcome with engineer.
Have you anything to say about the neighbours flue not being properly upright due to a too short upper bracket. The elbow joint does not look like it's meant to take the strain and the outer seal to the wall is distorted because the top is bent in and the bottom is being pulled out showing the whole fixture is being pulled up because the flue extension is acting like a lever. IMHO this looks like the integrity of the joint has been jeopardised and that is where the leak of condensate from the air intake is coming from. I guess after so long the components would be classed as unfit for purpose and require attention including a longer upper bracket and the exhaust elbows and seals would need to replaced.
The Installer should have not made this mistake and if the flue had been in a positon where it was readily accessible for inspection and maintenance (Reg28) the problem could have been identified and fixed a long time ago. I suppose that's why good old reg28 was made. It's OK I understand you do not critisize fellow engineers and don't miss an opportunity to critisize anyone who does (I am refering to others comments about me not yours, some quite harse) but when such a blatantly bad job is done then it really aught to be a matter for a website devoted to a well respected profession to do something or say something as it reflects on you all when cowboys are out there.
We can and often doo criticise other engineers. Move on
But you are coming across a proper bell and you now need to move on.
Your going round in circles.
You have been on to the council and they have sent you packing. Move on.
You have no practical appreciation of what you are talking about and you can read the regs till your blue the face but it wont change what you have already been told. Move on.
Reply to the thread, titled "Flue dripping from exhaust and from air intake." which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Yashimaki,
Rickster123,
