HALL of SHAME PHOTo`s
Didn't realise I'd been doing it wrong all these years chip board on brick walls walls.
You do really have to wonder about some so called professional tradesmen. DSC_0059.jpg
feeding a 105 e,FFS lazy bastids,been like this for 12 years,easy to upgrade the gas,boiler in loft,gas meter 40 ft below it with a strait external run,which is what we are now doing WP_20150602_001[1].jpgWP_20150602_003[1].jpgWP_20150602_004[1].jpg
good old new build plumbers
(ignore the level valve )
being held via the flush pipes, and yes them little pita flex valves were the only iso other than the main 2" stop valve
Nah. It was a quoted service in a school. Remedials go in a report back to the office for them to issue a quote.
Unless it affects safety or operation in which case it'd be an immediate remedial.
I know its probably a long debated topic, but isn't the plastic potentially popping of and spraying red hot water out a concern for safety?
If you're referring to the corrugated pipe, it's a condense.
The safety discharge pipe was well clipped and secure.
I think he meant the pushfit fittings. Always ambiguous how close to the unit they can get.
Had a survey at a factory to replace their hot water plant. Site manager mentioned that HWS circ was a bit poor, although the pump was running....
You just wonder wot goes through some engineers heads lol
The same thing (in the same place) which says 'lets put in a super mega-sized gas water heater and 100 gallon storage cylinder (which heats up in 3 mins from cold!!!) to serve several basins and a couple of sinks, don't bother to insulate the pipes because it'll keep the factory warm, oh, and while we're at it stick in a couple of booster sets to feed some washdown hoses but chuck in a couple of 100 gallon storage break tanks to feed them with electric immersion heaters to keep the water hot after they've come off the hot water system' :dead:
Barry98,
Harvest Fields,
