View the thread, titled "Oil and Multi fuel Stove Linkup - Part 1" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Still waiting for an answer to #16 and #20. Not that it will make a difference.
Posts like this remind me of my kids when they were 2. They would ask a question which I would answer and they would say no it isnt.
Now you either want advice, or you do truly think you have reinvented the wheel and thought that we would be queuing up to pat you you on the back. So either listen to the advice, which does come from a lot of experience or do one.
Could you post the start of your post code?
Just want to make sure I live nowhere near you.
The only problem there croppie is that I would struggle to have faith in the people that say they "know what there doing" when they ;
1) cant answer a simple question i.e. how does a 1KW heat leak rad dissapate heat from a 10KW stove (It doesn't)
2) Whilst professing how knowlegable they are - are apparently unaware that this system is fitted to off-the-shelf thermal stores(aka heatwell, because it is sold doesn't make it legal) - presumably (but i could be wrong) passing all relevant standards inc. building control and WRAS (the part you are on about doesn't as a means of control).
3) Appear to think that Danfoss (and other manufacturers) who designed and made these valves specifically for use (outside the uk) with heat exchangers for overhead protection on solid fuel heating systems are "silly" and don't know what they are doing.
Would you have faith in that person ? or the system they installed ?
Whilst these things may be available and legal elsewhere, they cannot be legally fitted in the UK as a satisfactory means of control.
You will do what you will do anyway as you know best. Don't try to get justification from anyone else and if you cant find someone to fit and sign it off, diy and try to get the paperwork yourself.
This thread is very concerning. For a project of this type, consult a HETAS engineer, it will save loads of grief and will be safe. Solid fuel is an uncontrolled heat source and therefore needs to be separated from the rest of the system, by, as previously said, a thermal store with heat sink radiators.
As stated in the first post the stove heats the buffer / accumulator - which is seperated from the rest of the system by a heat exchanger. With power on heat leak is provided by the pumped CH circuit. Without power 50Kw heat dump activates on overheat. To fit a heat leak rad would mean installing it in an uninsulated attic space, requireing gallons of antifreeze - and as no-one appears willing to admit -it is incapable of preventing an overheat condition at worst case scenario.
opinions that the heat exchanger will suffer thermal shock due to heat of store and incoming cold mains fail to recognise that every thermal store that uses a heat exchanger to provide DHW does the exact same thing in reverse.
As for HETAS engineer thats kind of what i was hoping for on the "oil and solid fuel forum"
You've missed out areas that we don't even have to think about while designing these systems because its basic to us.
you're just too blinded by your own ideas to listen to reason.
You didn't come here for advice, you came here to have your ego rubbed.
please go ahead and do this.
and come back when you've partially flooded you house and turned it into a sauna too.
p.s you're wrong on the heat exchangers, only a madman or a naive tool would even consider running a heat exchanger with a max of 91 degree difference........
i'm out.
You've missed out areas that we don't even have to think about while designing these systems because its basic to us. Would one of those things you dont have to think about be the ability to read ?
you're just too blinded by your own ideas to listen to reason. NOT MY IDEA ! - it was taken from a thermal store manufacturers web site! - that I linked to! (see below) Think it might be you who is too blinded by his own ideas !
You didn't come here for advice, you came here to have your ego rubbed. Yes my ego has been trulely rubbed - I am so proud of myself for asking advice on a thermal store manufactures system that i cut and pasted into a forum !
p.s you're wrong on the heat exchangers, only a madman or a naive tool would even consider running a heat exchanger with a max of 91 degree difference........ You mean like the ones fitted to every combi boiler sold ? on sealed systems pressurised to 2 bar ? With overheat stats rated at 107 degrees ? Are all designers at Worcester (or pick the manufacturer of choice) madmen and or naive tools ? Or are you speaking out of your discharge pipe !
i'm out. Thank God !
"my" design is on this previous post . . .
Nostrum: finally found the origional plan that set me on this track . Copied from Heatweb site DPS MultiFuel Heat Bank Thermal Store - hope it clarifies what i'm talking about.
Why even bother coming on to this forum, you obviously think you have all the answers and will not be moved from your own idea's, which are frankly floored, but its not going in. Go ahead and do your cheap little install and lets hope you don't kill any of your family in the process. I'm out.
Seriously !
NOT MY IDEA !!!!!!!!!!!!! NOT MY IDEA !!!!!!!!!!!! NOT MY IDEA !!!!!!!!!!!
as far as all the answers - i'm still waiting for a single response explaining how a heat leak rad can prevent boiling !
Only one poster suggests a feasable alternative which i'm looking at - so hardly "will not be moved".
will not be moved based on opinions of people who refuse to justify their answers with nothing more than "we know but were not telling" or "trust me i'm an expert but can't explain what your asking" is more like it !
If youv'e said your piece and don't want to or can't explain then why post in the first place?
If you think the firm that designed this sytem are wrong - explain why - maybe with your expert knowledge you should contact them directly to tell them their systems are dangerous . . ? But no you choose to critisize me, and "my" silly ideas !
If you post that "your out" then stay out ! Why cause all the hastle ?
Seriously !
Grow up
No one is going to help you with that attitude
your not listening
What you want to do is against regulations in UK
End of story
Your attitude stinks
The only advice you're getting is get someone in. What you are proposing is dangerous.
You are demonstrating a serious lack of understanding which we cannot help you with and you are now winding members up.
Thread closed.
Reply to the thread, titled "Oil and Multi fuel Stove Linkup - Part 1" which is posted in Boiler Advice Forum on Plumbers Forums.
