Oct 21, 2019
DIY or Homeowner
I am trying to combine some push fit waste pipes that go directly into the outside drain. They are 34mm. Can anyone tell me where I can get this size? It all seems to be 32 or 40 mm. Thanks
If your pipe diameters are a couple of mm different you probably have a combination of push fit pipe and solvent weld.
Use a multifit coupler or elbow from McAlpine to connect them.
Reactions: DuncanM
