What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Nice.
I have fitted quite a few heating coils in changing rooms and drying rooms
I have only found one improvised heating coil possibly for drying and it was sat on top of a cylinder in an airing cupboard. The stupid thing was it was plumbed into the hot distribution pipe. It was cooling the water down before it reached the hot taps. It was about ten metres of 22mm tube in a coil just on the hot distribution in the airing cupboard. Such a coil on the heating side would have been ok as it would be just like another radiator but on the hot distribution it's seems pretty daft to me.
My other thought was it was a silly "energy saving" device that whoever put it there thought maybe it'd pick up some of the cylinder heat loss and put it into the hot water. I made a thread on it here ages ago and nobody could give a definitive answer.
What a silly way to go about it I thought. It was generating a "parasitical loss" on the cylinder and cooling the water in the distribution system down.
This week I've been sorting my car out for its' MOT in a couple of months.
Oil and filter change yesterday, today I planned swapping both front anti-roll drop links, started quite late so only managed one as it was awkward as hell.
Tomorrow I'll do the other drop link and on Friday it will be the offside track rod end. Then should be good to go and will have saved £240 garage fees 😀 😀 😀
First boiler swap since lockdown friend of my daughters so sorted it out for her , only been in the house since Feb and inherited a Baxi duo Tec mk1 poorly maintained a leaking heat exchanger took the board out as well , with things as they are and money tight went for a entry level Ideal Classic 30 all in all a decent little boiler doddle to fit 5 year warranty keep safe all . Kop
Boiler £492 + Vat - flue £69 - 29 + Vat Scott, I got the boiler & flue , Honeywell T4 , Magnaclean micro , chemicals , 6m of 22mm + 6m of 15mm , £180 piece fittings bucket , filling loop and 15mm salamander inline descaler for £1000. Cheers kop
I wish they didn’t put mechanical clocks in the cheaper boilers!
Agreed mate I supposed they are aimed at rental and landlord type properties may be ? add a stat job done may not meet boilier plus but loads out there that don't and who is going to police it nowadays a the best bud . Kop
You can’t meet boiler plus with the mechanical clock and room stat as far as I know.
So you need Weather comp.
Or an external programmer/stat and tell the user not to touch the built in timer as it must be permanently on.
I fitted an Independant c24 recently for a landord, I used a Salus wireless room stat as it was the cheapest available. Doesn’t comply but like you say, who’s going to check.
That's what I did mate timer on constant and Programmable Honeywell T4 which meets boiler plus bud .
[automerge]1587622515[/automerge]
Better picture Scott
My first biggish job near completion since lockdown started stripping out Thursday and Friday last week , this shower room needed turning round quickly so went for multi panel to blend in with the existing tile that was installed 5 years ago and still looking good , the Victoria plumb shower and tray installed hadn't faired so well was leaking badly and looked shabby , I installed a Aqualisa Zuri smart shower with the processor box installed above in the loft connected to a Viessman 100 combi and Qualitex shower tray and wetroom glass, just the wiring, commissioning, lagging , and the clearing up to do today so 4.5 days which I think is reasonable cheers chaps keep safe . Kop
Panels actually look decent. Which ones you use and how do you attach them?
Hi KOP, I was told by aqualisa that a flow limiter can damage the pump so could only go down to 10l/min (if I remember correctly) - what do you go down to and have you had any problems?
I too have wanted to hold the bugger back occasionally!
9 litres a minute bud I will contact Aqualisa and check ? after second thoughts I may adjust where I limited the flow to the incoming supplies that way theres no back pressure , the stainless steel grate is the problem luckily my brother is the production manager in a factory that produces sheet metal products so hes going to fabricate a new one with 40 more holes in then restriction can come out ??? cheers Kop
You’ll probably have a market for those grids! I find positioning the riser rail/fixed head makes a hell of a difference to waste removal - but of course this has to be run past customer, if it wasn’t for them this job would be easy.
Update chaps after talking to Aqualisa technical , I have adjusted the processor control unit to HP eco mode from combi mode this reduces the flow by 2 litres a minute and removed the flow limiter it is not guaranteed to work faultlessly and can fluctuate slightly on temperature but a 2 litres a minute saving is worth trying also getting a grate made with 40 extra holes so should help. Kop
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
ShaunCorbs,
