What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Boiler £492 + Vat - flue £69 - 29 + Vat Scott, I got the boiler & flue , Honeywell T4 , Magnaclean micro , chemicals , 6m of 22mm + 6m of 15mm , £180 piece fittings bucket , filling loop and 15mm salamander inline descaler for £1000. Cheers kop
I wish they didn’t put mechanical clocks in the cheaper boilers!
Agreed mate I supposed they are aimed at rental and landlord type properties may be ? add a stat job done may not meet boilier plus but loads out there that don't and who is going to police it nowadays a the best bud . Kop
You can’t meet boiler plus with the mechanical clock and room stat as far as I know.
So you need Weather comp.
Or an external programmer/stat and tell the user not to touch the built in timer as it must be permanently on.
I fitted an Independant c24 recently for a landord, I used a Salus wireless room stat as it was the cheapest available. Doesn’t comply but like you say, who’s going to check.
That's what I did mate timer on constant and Programmable Honeywell T4 which meets boiler plus bud .
[automerge]1587622515[/automerge]
Better picture Scott
My first biggish job near completion since lockdown started stripping out Thursday and Friday last week , this shower room needed turning round quickly so went for multi panel to blend in with the existing tile that was installed 5 years ago and still looking good , the Victoria plumb shower and tray installed hadn't faired so well was leaking badly and looked shabby , I installed a Aqualisa Zuri smart shower with the processor box installed above in the loft connected to a Viessman 100 combi and Qualitex shower tray and wetroom glass, just the wiring, commissioning, lagging , and the clearing up to do today so 4.5 days which I think is reasonable cheers chaps keep safe . Kop
Panels actually look decent. Which ones you use and how do you attach them?
Hi KOP, I was told by aqualisa that a flow limiter can damage the pump so could only go down to 10l/min (if I remember correctly) - what do you go down to and have you had any problems?
I too have wanted to hold the bugger back occasionally!
9 litres a minute bud I will contact Aqualisa and check ? after second thoughts I may adjust where I limited the flow to the incoming supplies that way theres no back pressure , the stainless steel grate is the problem luckily my brother is the production manager in a factory that produces sheet metal products so hes going to fabricate a new one with 40 more holes in then restriction can come out ??? cheers Kop
You’ll probably have a market for those grids! I find positioning the riser rail/fixed head makes a hell of a difference to waste removal - but of course this has to be run past customer, if it wasn’t for them this job would be easy.
Update chaps after talking to Aqualisa technical , I have adjusted the processor control unit to HP eco mode from combi mode this reduces the flow by 2 litres a minute and removed the flow limiter it is not guaranteed to work faultlessly and can fluctuate slightly on temperature but a 2 litres a minute saving is worth trying also getting a grate made with 40 extra holes so should help. Kop
Started a bathroom upgrade this week new owner hates the assisted bathroom look and it's fixtures and fittings so a full strip and new tiling is taking place, updating everything . Kop
I hate bathrooms 😄
This is the tray I asked for advice on another thread. Went for SBR and flexible tile adhesive in the end.
View attachment 44319View attachment 44320
Looks tidy Scott 👍 sorry bud must of missed that one I would have done the same . What were the wall panels made of ???? Kop
[automerge]1593064039[/automerge]
Got a few tiles up it all taking shape nicely . Kop
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
Chuck,
