Sharp Point
I’d like to see the statistics between Germany and the U.K. on gas explosions from leaks, that’ll be interesting
welded should be better than any soldered joint!If I can decipher his posts, I think the gas pipework in his home country is welded and welded joints can be terrible, so it makes sense to test at much higher pressure
As normal checking ecv Letby 10mbar and after that tightness test of 20mbarSo how would you carry out a tightness test in a domestic property after making an alteration to the installation pioework ?
So you’d be happy with it holding at 20mbar for 3 mins ?As normal checking ecv Letby 10mbar and after that tightness test of 20mbar
That would be interesting to me too.I’d like to see the statistics between Germany and the U.K. on gas explosions from leaks, that’ll be interesting
You are right scott. I know that and that’s you would not be able to test the pipework with higher pressures. You would need to test them without having anything connected. We also check only the downstream side of itwelded should be better than any soldered joint!
We should test at 20mb to avoid regulator lockout and not testing pioework the other side of it
Of course. According to what I learned here I am happy with 3min holding the pressure at 20mbar. If I can’t smell gasSo you’d be happy with it holding at 20mbar for 3 mins ?
Agree with you. Welding is practing it comes with time. You will need to do it very regularly to have a good decent weld done which doesn’t leak. Do you actually learn welding in apprenticeships? I remember we had to bend steel pipe with sand, welding joints, soldering copper, brazing, ... using basically all kind of materials and fittings.Not everyone can weld, lots of people can solder. Soldering is easy... you can pretty heat the front of the fitting and add solder... job done( usually)
Try welding a small pipe with tig/ stick / mig
Different story..
So no, welded joints could potentially leak
So what’s the purpose of the 1 bar test if your happy with the 20mbar test ?Of course. According to what I learned here I am happy with 3min holding the pressure at 20mbar. If I can’t smell gas
We don’t do lead at all. It’s forbidden and should be cut out when seen. Very unhealthy stuff.No, steel welding isn’t part of plumbing qualifications, lead welding is though.
Different argument but quoting German stats again Ron. One day working to German regs will get you in to trouble. But you know best. Best to leave him to it @ShaunCorbsdont want to be rude but your / were not in germany doesnt matter what the german standards are there not ours
You did not get my point harvest. I was saying that I stick to the rules here but would love to see some changes. The above statements are just my opinions nothing more or less. I am not working according to german standards, first of all I don’t have the parts and materials to carry out such a great work which is obviously a downside but it is what it is. It seems like you misunderstand me quite often. It is either down to my English or perhaps my understanding of your language.Different argument but quoting German stats again Ron. One day working to German regs will get you in to trouble. But you know best. Best to leave him to it @ShaunCorbs
So just to clarify, I stick to the rules and regs over here but have a different approach to what is right and wrong. I am just having a different opinion about plumbing in uk and in Germany. Have you ever been to Germany? Perhaps you should give it a go and come to see some of the plumbing events. Next one this year I would like to invite you and show you around if you are up for it
I can’t promise to get you vw parts but the event is the biggest in Germany which is fun.I’ll come, as long as you can buy me some cheap Vw high power race parts, from some of the German engineering companies 😀
Vaillant are awesomeWhat and get that ‘Vaillant’ crap rammed down my throat for the day.
Agree with you even though I don’t like to but you are right 🙂😀🙂😀Vaillant are awesome
