Well you don’t as you’ve said you test gas carcass at 1 bar which could hide a small leak
Don’t think I ever mentioned that I test pipes in uk with 1bar. Yes I agree, I did say I would and that would be the appropriate way to pin point leaks, hairline cracks etc. But I never said I do and don’t stick to the uk rules. It’s a slight difference of having an opinion and doing it as I said I would. However, you won’t get my point as you always seem to look for excuses. Just admit for once that other people are right too and know their trade. Or are you to proud
Yes, you would need to otherwise you will ruin the appliances. You can only test them via there operating pressure as you know. But when it comes to testing the pipework throughout the property when installed new then you will need to use the appropriate fittings to cap them off and test them with higher pressure ( but that’s the way we do it in Germany ). We do 2 test before bedding pipes into the concrete, load testing ( 1bar with air or N ) for 30min -1hour and then a 15 min test leak test.
Sorry but it is difficult to explain german terms in English. I think you can’t be careful enough when it comes to gas. I know it’s done differently here and I do whatever is required but I would wish few things would be different.
This doesn’t sound like an opinion mate. It sounds like standard practice.
True it is standard practice but in Germany and not here in uk. I just stated few things how we do it in Germany I don’t think it’s wrong to mention some facts. You don’t seem like you like Germany 🙂
Nothing against Germany mate. It helped make England strong before we were properly part of the E.U😉😛😛. At my moms house I am allowed to walk around in just my pants. Does that mean I can do it everywhere else?
On open forum I would be like you mate 🙂 not all the things which we are allowed to do are the rights things to do. Regulations both in Germany and England could be still improved.
Does Germany have an equivalent to gas safe?
It is slightly different compared to uk. Most people works for companies rather than being self employed. You will need a master degree to be able to run an own business. However, each company and installer needs to be registered though.
Let’s get this right, you need a masters degree to start any business up?
Love a bit of Rammstein, but Klinsmann thats another story
Did the engineer check the connection at the gas hob? 9 out of 10 leaks I go to ends up being under gas hob on compression fittings.
Yes, if you want to work for yourself. It is not as simple like calling a company and getting self employed. You will need to hold a degree and that cost 12-15k
