0.5mb drop on tightness test - Should I be worried?
View the thread, titled "0.5mb drop on tightness test - Should I be worried?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
next time you do a test after your done put your hand on the gas pipe and watch the gauge now imagine a windy / cloudy day the gauge could go down 3 - 4 mbar for nothing just a bit chilly
And yes as it’s within safe limits so in short your making work for your self
I get that mate , I just have mad OCD 😳
So if in that situation, you had a 3mbar drop on a g4 metre, your conscience gets the better of you and you decide to investigate. You isolate the appliances and prove the pipework is sound. You then test each appliance individually and find the gas valve on the fire is passing. What then? Do you leave it or have to condem it?
Have to remove / cap the appliance with permission if the original test was outside specd limits for said meter
Yeah but 3mbar is within tolerance so would you still have to cap it?
No within spec and no smell leave it you could note it down
As you wouldn’t go looking for one so no appliances removed / capped to test just the line
Same but if you get reported gas safe won’t be happy with you
Why would I be reported for that though mate ?
Not trying to argue here, I’ve just never been told this.
At college when the question of trying to find a drop even if within limits was asked the answer was there no need but if you want to try and find it then you can.
As it’s acceptable and safe
Let’s say you’ve had a 2.5 mbar drop you spend 1/2 a day looking around and testing you find it and fix it
Give the customer a bill of let’s pick a figure £200 every other engineer hasn’t picked this fault up / says it needs repairing
Customer says how much, they phones gas safe up and say I want to see if something sounds right with you
I’ve had a gas leak of 2.5 mbar and the engineers found it and repaired it but it’s cost me 200 did it need repairing
They will ask the customer a few questions or send an inspector out etc
And they will say no it’s within acceptable limits Customer won’t pay the bill etc
This confuses me too, so harvest has said once he found where the gas was coming from, he would cap it as obviously it isn't acceptable for a valve to be passing gas. But if you haven't gone looking for the leak it's acceptable? Just seems that if we're ignorant we can pass it off. I know we're only following rules but from a safety point, why aren't we forced to confirm whether the drop is through fluctuation or an actual leak? The no smell of gas rule is a little ignorant too as the gas will just go out the flue or chimney so it's unlikely you'll smell it.
Ok I get where your coming from with that side of things.
I thought you were meaning I wouldn’t be doing something safely.
I wouldn’t do that though tbf, if I chose to do that just for my own piece of mind then any extra time taken would be on me.
Thing is if you take that stance good luck as you could be buying new cookers and gas valves/ fires for people out if your own pocket and can’t charge for
Complete carp! Any legal establishment on this island would merit any safety based repair, regardless of whether it’s within spec.
Nope and your other post your test is only valid for that day / the time your there say you have a massive gas leak a month after your not responsible/ no liability
Wasn’t the op’s initial post about panicking about being told she had a leak, I would put a hefty wager that any homeowner would react the same... to be told they had a gas leak. Now don’t get me wrong, I certainly don’t go making a meal to the custard about having a gas leak,in the view to creating extra work( as long as it’s within tolerance)
My reply to you previously, was about ‘being done’ by the gas police.
Things like that are what the tolerances are for so as long as it was within it would be ok.. however, I would inform the customer of the situation and explain to them about the permissible drop and that it is safe to leave.. or I could repair/renew it if thats what they wanted.
This way I have covered all bases.
they would say its within safe limits why did you go looking for the leak when you didnt need too
Maybe, but I certainly don’t think you’d ‘get done’ For being over safe.
Me personally would starting raising my brow to a 3mbar drop
Reply to the thread, titled "0.5mb drop on tightness test - Should I be worried?" which is posted in UK Plumbers Forums on Plumbers Forums.
EastMidsTiler,
firemant,
